VI Analyzer Enthusiasts Documents
VI Analyzer RSL Exporter
This VI retrieves the stored analysis results in a VI Analyzer RSL File. Use this VI to create your own mechanism for displaying or exporting VI Analyzer results.
Within the Results Data arrays, each results cluster (Pass, Fail, Skipped, etc.) will have a 'row' and 'column' value. Use these values to index into the Raw Results Data array to retrieve a specific test result.
The VI Analyzer RSL Exporter VI will work in LabVIEW 2012 or later. It does *not* require the VI Analyzer Toolkit to be installed.
The VI Analyzer RSL Exporter 7.1 VI will work in LabVIEW 7.1 through 2011. If you are using LabVIEW 7.1 through 8.5, you must have the VI Analyzer Toolkit installed. If you are using LabVIEW 8.6 through 2011, you do *not* need the VI Analyzer Toolkit installed.
DNatt, LV R&D
Comments
Example Gatekeeper
Example Gatekeeper
In the latest version of this utility, I have added an output to the VI that returns the array of Test Config Data clusters.
DNatt, LV R&D
Contributors
