When I load a .viancfg file any (custom) test that is installed on my pc but not defined in the file is enabled by default by the VI Analyzer. This means that whenever I use a test configuration that was created by a colleague all (custom) tests that are on my pc but not on my colleagues are enabled and therefor we don't run exactly the same test. I was wondering if there is a way to change this behaviour and to disable the tests that are not defined in the .viancfg file by default?
