VI Analyzer Enthusiasts Documents
Test - Property Node Name Format
This test returns a failure for any Property Node or Invoke Node that is set to the "No Names" Name Format:
Code is more self-documenting when property and invoke nodes are set to "Short Names" or "Long Names" Name Format.
This test is saved in LabVIEW 2012. Follow the instructions here to install and use this test.
Comments
shb
on
Could this be extended to also check the "Name Format" of "Call Library" nodes? Setting it to "Names" is more self-documenting than "No Names".
Unfortunately, I do not find the property for this (on a "CallLibrary" refnum).
Contributors
