VI Analyzer Enthusiasts Discussions
Spell Check fails VIA tags
I'm not sure if this is some US/UK spell checking issue, but I first got some "failures" for Parallelizable Loops. This is fine - the loop could be parallelized. I choose not to, because the number of iterations is always likely to be small.
To prevent the "failure" in future, I add "#via_ignore Parallelizable Loops", copying the name from the Results Window.
Next time I run the tests, I get a failure of the Spell Check test with "This free label contains the misspelled word "Parallelizable"."
Could we have the test names (as recognised by the tags) always accepted by the Spell Check?
GCentral
(2,295 Views)
Accepted by topic author cbutcher
Thanks for reporting this. It should be fixed in VI Analyzer Toolkit 2020.
(2,247 Views)
