VI Analyzer Enthusiasts Discussions
New Experimental INI Token for VI Analyzer 2020
In VI Analyzer 2020 and later, you can experiment with the following INI token:
VIAnalyzerSuppressCompile=TRUE
With this INI token, LabVIEW will try to skip compiling VIs as it opens their VI references during an analysis session. When you are performing an analysis on a large block of code, you may see performance improvements in the analysis time.
Let me know if you try this INI token. I'd like to know about any improvements to analysis time, as well as any crashes or other strange behavior.
Message 1 of 1
(2,862 Views)
