VI Analyzer Enthusiasts Discussions
INI token to aid in VI Analyzer UI debugging
If you are seeing strange behavior in the VI Analyzer UI (or the Results Window UI), you can add the following LabVIEW INI token to help with debugging:
LVdebugKeys=True
This token will enable error handling dialogs to appear while using the VI Analyzer UI (or the Results Window UI). The token also adds a lot more debugging capability to LabVIEW than this, but you can explore those avenues with a google search if you so desire.
Message 1 of 1
(3,959 Views)
