02-18-2016 08:20 AM
I am working on creating tests that are specific to our company's standards guideline. I just started. The first one that I am working on is the following.
- Suppress dialog error reporting for unattended or remote operation.
The only idea I have is to query the block diagram and come up with a list of VIs used and then compare them to the known list of dialog producing VIs. But I am having difficulty finding a way to create this list programatically.
I have a others that I need, but I wanted to take this one at a time.
Any ideas/help would be appreciated!!!
02-18-2016 10:55 AM
I don't think there is a way to generate this list programmatically, since a "dialog" could be any VI that has its panel programmatically shown, and is statically (or dynamically!) configured to be a modal dialog.
So you would need to provide a list of VIs and functions. And you'd probably want to provide a way for users to specify additional VIs that they know are used as dialogs in the application being tested. As far as stuff that ships with LabVIEW, I can think of:
General Error Handler.vi
Simple Error Handler.vi
One Button Dialog
Two Button Dialog
Three Button Dialog.vi
Any of the File I/O functions (and some VIs) with an empty path wired in will pop up a file dialog
File Dialog (function and express VI)
This is not a comprehensive list, just the stuff I can think of off the top of my head.
02-18-2016 05:15 PM
I have another test that I am running into trouble with. How can I test to make sure all VI's that have error inputs and outputs have them connected on the block diagram to something? I have been going through the list of the ones that ship with LabVIEW. I hope I haven't missed it.
Thanks.
02-19-2016 12:42 AM
You have to disable automatic error handling, so VI's without wired error connector won't produce dialogs.
02-19-2016 10:29 AM
Yes that is something to do. But I also want to make sure the designer has wired up all possible error outputs and done the proper error handling on them. I guess this is probably just going to have to be a visual inspection.
02-19-2016 10:33 AM
The Block Diagram > Warnings > Error Cluster Wired test in the VI Analyzer Toolkit will return a failure for any diagram object that does not have its error output wired.
02-19-2016 03:20 PM
I have another issue I need help with. It appears that after I am able to run the tests that I create for VI Analyzer but I can't look at the errors from the results list. I have attached the lib for one of the tests I am having issue with and a picture of the error. This problem occurs even when I run the test by itself.
I have trying to change different things like adding or removing Close Ref VIs. I thought maybe closing the references to the controls was the problem.
The latest change I made was to create a seperate array for the references for when I convert them to a another class to be able to get the right informaiton out of them. But that didn't seem to help.
I also added the test VI I was using.
I am assuming that whatever I am doing wrong on this test I am doing wrong on all the tests that I created. I am running this on LV2015.
Thanks for your help!!!
02-19-2016 03:23 PM
You need to populate the RD VI of your test. See the "Configuring the Test to Highlight Failures" section here for more information:
http://zone.ni.com/reference/en-XX/help/371361G-01/lvvianalyzerhelp/writing_vian_test/
02-19-2016 03:55 PM
Is it possible to select a different folder for the User-Specified test other than:
//LabVIEW Data/VI Analyzer Tests
I am asking because I want to be able to put my tests that are created in a source control repository.
Thanks.
02-19-2016 03:59 PM
There are only two locations that VI Analyzer tests can reside:
[LabVIEW Data]\VI Analyzer Tests
[LabVIEW 20xx]\project\_VI Analyzer\_tests
If you want to keep your tests in source control, I recommend using VIPM to create a package that installs the tests to the [LabVIEW 20xx] location. Most people I know that take this approach create a folder in there with their company name, then categorize tests under that folder.
