10-30-2026 05:12 AM
Solved! Go to Solution.
10-30-2026 02:12 PM - edited 10-30-2026 02:13 PM
If you're completely new to the VI Analyzer Toolkit, I suggest looking through the slides at https://vianalyzer.dnatt.org/. There is a recording link there, but it's to a very old recording... I should probably make a new recording of that presentation
Since the VI Analyzer Toolkit is a licensed product, the toolkit tests are part of a licensed library, which means there's no official way to make a copy of the shipping tests. For the tests you mentioned, I think most of their code is not password-protected, which means you could conceivably make edits to them. Assuming you're in LabVIEW 2024 Q1 or later, if you enable write permissions on the LVAddons folder and run LabVIEW as Administrator, you can edit the non-password-protected toolkit VIs in C:\Program Files\NI\LVAddons\viawin\1\project\_VI Analyzer\_tests. Although it's generally considered bad practice to make changes to VIs that ship with LabVIEW and its toolkits, there really isn't any other option for modifying the behavior of shipping toolkit tests.
If you want to create new tests, you can do that with the Tools > VI Analyzer > Create New Test tool.
Here are the resources I'm aware of that provide additional VI Analyzer tests outside the VI Analyzer Toolkit:
LabVIEW Real-Time Best Practices (installed with the Real-Time module, appears under a new 'Real-Time' category in VI Analyzer)
Let me know if you have any follow-up questions.
