We are making a lot of VI's that are reentrant and point by point to our simulation models. The challenge is to make a unit test with NI's UT framework without using a wrapper VI.
Test Vectors are the answer. You can use these to test VIs like this, I had to do this with some FPGA VIs.
The only problem is with reset behaviour, although test vectors repeatedly call your VI each call is a new call so if you use this as an internal reset it may cause some problems.
James Mc ======== CLA and cRIO Fanatic My writings on LabVIEW Development are at devs.wiresmithtech.com
