07-17-2018 09:19 PM - edited 07-17-2018 09:28 PM
I spent several hours trying to figure this one, so I thought I would share in case anyone else runs into this. I also reported via Service Request #7746280. Hopefully, NI can file a CAR for this issue and maybe it gets fixed one day.
Background:
LabVIEW 2018 loading a project saved on LabVIEW 2017
The project included several demonstrations of different unit test tools, among them JKI VI Tester.
LabVIEW 2017 did have JKI VI Tester installed
LabVIEW 2018 did not have JKI VI Tester installed
The unit under test is a class method, but the object is not used at all for the test.
Problem:
when opening the project in LabVIEW 2018 and attempting to run the Unit Test Framework tests, the test reported an error.
When opening the lvtest itself, it was blank, no test case name no inputs, no outputs. When attempting to import values from VI a message would pop up telling me that I needed to refresh the test. After refreshing another message popped up explaining that the class couldn't be loaded.
07-17-2018 09:22 PM
Solution:
Install JKI VI Tester for LabVIEW 2018.
Unit Test Framework tests work like a charm.
What I think the problem was:
Unit Test Framework somehow cares about the other classes in the project, even though the unit under test is only calling a class that is valid and fully functional.
The error about the class not being able to load did not refer to the class in the unit under test but to the other classes present in the project for JKI VI Tester. Since JKI VI Tester was not installed, the classes could not be loaded.
Once I installed JKI VI Tester, all classes in the project could be loaded and the unit test worked again.
What I would like for NI to do:
Fix the Unit Test Framework so it only looks for the classes that are related to the unit under test and disregards if there are broken classes in the project.
Fab
07-30-2018 06:42 PM
CAR 707315 filed by NI regarding this issue.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
