08-25-2015 04:31 PM
I am refactoring and trying to move some .lvtest files into a new directory and having problems.
Does anyone know how to do this?
I was going to ask how best to do this but right now any way to do it would be an improvement
Many thanks
David
08-25-2015 07:17 PM
One way to do it is to move the .lvtest files to the new directory and then open them with notepad and readjust their relative path to the VI under test.
The path to the VI under test can be relative.
Open one of the lvtest with notepad before moving them and check if the path to the VI under test is relative or not. Try changing it (from relative to full path or from full to relative) and verify that you can still open the lvtest via LabVIEW. Once you know you can do this change, you can do what I outline above.
I don't know if this is the best way, but it definitely a way
Fab
08-25-2015 08:25 PM
Fabulous!
That works.
The only other thing I needed to do was
All working and the editing means I don't get the breakage I was having by choosing different VI's
Brilliant!
Thank you
08-25-2015 08:58 PM
If memory serves I've used the rename function to change the disk location but kept the filename the same. This seems to update the relative referencing.
