USRP Software Radio
usage of GNU radio in signal capturing using USRP
Hi ,
I am completely new to this topic. So I have some basic doubts .
I am using a signal generator to generate a radio standard(LTE) and the signals are recorded using the USRP N310.
Also a GNU Radio is used .
I know that GNU Radio is a open source software development toolkit that provide signal processing blocks to implement software radios.
My question :
1.Is Gnu Radio a software to build the blocks to capture the signals in usrp or does it have any other function too.
2.Is labview and Gnu radio has the same purpose.
(1,643 Views)
Hello Dear.
As I understood you are using GNU Radio. Are you thinking of using LabVIEW instead ?
Best Regards.
(1,530 Views)
