USRP Software Radio
sync tx and rx sine waveform
hello. I want to synchronize the transmitter and receiver that use continuous sine signal. I can not find the steps to check does the receiver got the real-time signal or got some delay.
I differ the channel gain of channel 0 and channel 1 at the transmitter and change them every 2 seconds (duration can be changed) and I want the receiver to check whether is it channel 0 or channel 1 based on the received power. but I have to synchronize the time between them to make an accurate estimation. here is the picture of Tx and Rx scheme
I will be glad if you can give me some help. thank you
Message 1 of 1
(900 Views)
