USRP Software Radio
niUSRP 1.2 / USRP N210 / beat frequencies LO
I made a Labview 2012 program based on some examples of the ni USRP 1.2 software, for being executed in my USRP N210. The objective of my program is to measure a signal, that right now is generated by a RF signal generator, after doing an fft plot of it, and show it in a graph chart. I also want to show a plot with the values of the max in dBs of the signal and its contiguous bins. The problem that i have is that i have some type of 'continous' signal that doesnt let me focus on the one signal that i want to measure and work with. I have read about some type of beat frequencies generated by the LO of the USRP n210 motherboard, but im not completly sure about that. I also want to note that i have the tvrx2 daughterboard installed. Any question, answer or recomendation will be very welcome! Thanks
Santiago Mariño Cambeiro
(6,048 Views)
Hi Santiago,
Most likely what you are observing is the so called "LO leakage".
A typical workaround is to shift the LO frequency outside the frequency band that is monitored, keeping
in mind that you are restricted by the A/D bandwidth (check out
the USRP property node for an item called LO Frequency [1]).
As a side node, regarding your application, I've seen that you are using a laptop.
Be aware that the achievable sampling rate depends on the "quality" of the embedded NIC and the driver
parameters (it all depends on the bandwidth you are targeting).
L
[1] http://zone.ni.com/reference/en-XX/help/373380B-01/usrppropref/pniusrp_lofrequency/
(5,989 Views)
