USRP Software Radio
conditional write USRP IQ data to TDMS file
I am capturing RF signals by USRP device. I want to write IQ data to TDMS file under condition, if either of their absulot values (I or Q) is greater than some threshold value.
I use the case structure. It works for “True” case. But for the “False” case, when condition is not satisfied I do not want to write any data to the TDMS file (now in my code I am feeding zero for output of "false" case, i need to modify it to stop writing any data for "false" case). So my question is I do not know how to complete the "false" case. Or may be I need to use different structure.
I attached the code.
(3,042 Views)
Hi Jeff100,
It sounds like you will want your TDMS write function in a case structure where in the false case you don't write anything. Right now, with your false case, there is no change in what happens with the TDMS write function.
Shalini M.
Partner Development Engineer
Alliance Partner Network
(3,010 Views)
Hello Shalini,
Yes, I want to write to the TDMS file just during "true" case. But for "false" case I do not want write to TDMS file.
In my code, right now, for the "true" case it passes data to write to TDMS file. but for "false" case it writes zero to TDMS.
How I can stop to writing to file during "false" case. In other words, instead of passing/writing zero (that is what I did) how I can pass nothing during "false" case.
Thank you
(3,007 Views)
If you add a case structure around the TDMS write function and only write data in the true case and pass the TDMS reference without the write function in the false case, that should accomplish what you described.
Shalini M.
(2,977 Views)
