Hello everyone,
I have an X310 SDR connected to my system via a MOLEX cable over a PCIe card.
I need to run a Docker container that interacts with this SDR, but I have trouble passing the X310 into the container.
Specifically, the container seems to require network_mode: "host"
for proper functionality.
However, I can't use this because I need a custom network configuration with specific subnets etc, and network_mode: "host"
conflicts with that.
Here are two Docker Compose configurations illustrating the problem:
1. With network_mode: "host"
(works but not usable in my case):
version: '3.8'
services:
ettus-uhd:
image: openverso/ettus-uhd:3.15.0
container_name: ettus_uhd_container
privileged: true
devices:
- "/dev/bus/usb:/dev/bus/usb"
volumes:
- /usr/share/uhd/images:/usr/share/uhd/images
network_mode: "host" # Using host networking mode
command: uhd_find_devices
restart: unless-stopped
When the container is started, uhd_find_devices lists the X310 just fine:
2. Without network_mode: host
, attempting to mount /dev
and /proc
version: '3.8'
services:
ettus-uhd:
privileged: true
devices:
volumes:
- /dev:/dev
- /proc:/proc
When the container is started, uhd_find_devices says no devices found:
My question: How can I make the SDR accessible to the Docker container without using network_mode: host
What parameters do I have to set, what do I have to mount into the container?
I need a solution that allows me to use a custom network while still accessing the PCIe-connected SDR.
