From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
08-17-2018 04:11 PM
Hi, I am running matlab 2017b with NI USRP2921. The USRP support package is installed. I got errors running findsdru, and probesdru('192.168.10.2') from matlab command, and could not Tx or Rx. Anybody can help? Thanks.
>> findsdru
Checking radio connections...
Win32; Microsoft Visual C++ version 14.0; Boost_105600; UHD_003.009.007-vendor
---------- see libuhd version information above this line ----------
---------- begin libuhd warning message output ----------
The MTU (1472) is larger than the FastSendDatagramThreshold (1024)!
This will negatively affect the transmit performance.
See the transport application notes for more detail.
---------- end libuhd warning message output ----------
---------- begin libuhd error message output ----------
The daughterboard manager encountered a recoverable error in init.
Loading the "unknown" daughterboard implementations to continue.
The daughterboard cannot operate until this error is resolved.
AssertionError: assertion failed:
1041666.6666666666 is not a valid tx dboard clock rate.
possible values are: [100000000, 50000000, 33333333.333333332, 25000000, 20000000, 16666666.666666666, 14285714.285714285, 12500000, 11111111.111111112, 10000000, 9090909.0909090918, 8333333.333333333, 7692307.692307692, 7142857.1428571427, 6666666.666666667, 6250000, 5882352.9411764704, 5555555.555555556, 5263157.8947368423, 5000000, 4761904.7619047621, 4545454.5454545459, 4347826.0869565215, 4166666.6666666665, 4000000, 3846153.846153846, 3703703.7037037038, 3571428.5714285714, 3448275.8620689656, 3333333.3333333335, 3225806.4516129033, 3125000].
---------- end libuhd error message output ----------
ans =
1×2 struct array with fields:
Platform
IPAddress
SerialNum
Status
ans =
'Win32; Microsoft Visual C++ version 14.0; Boost_105600; UHD_003.009.007-vendor
-- Opening a USRP2/N-Series device...
-- Current recv frame size: 1472 bytes
-- Current send frame size: 1472 bytes
UHD Warning:
-- Creating WSA UDP transport for 192.168.10.2:49156
-- Creating WSA UDP transport for 192.168.10.2:49158
-- Creating WSA UDP transport for 192.168.10.2:49157
-- Creating WSA UDP transport for 192.168.10.2:49159
UHD Error:
_____________________________________________________
| Device: USRP2 / N-Series Device
| | Mboard: N210r4
| | hardware: 2577
| | product: 30195
| | mac-addr: a0:36:fa:36:30:eb
| | ip-addr: 192.168.10.2
| | subnet: 255.255.255.255
| | gateway: 255.255.255.255
| | gpsdo: none
| | serial: EER10VBNX
| | FW Version: 12.4
| | FPGA Version: 11.1
| | Time sources: none, external, _external_, mimo
| | Clock sources: internal, external, mimo
| | Sensors: mimo_locked, ref_locked
| | | RX DSP: 0
| | | Freq range: -50.000 to 50.000 MHz
| | | RX DSP: 1
| | | RX Dboard: A
| | | ID: XCVR2450, XCVR2450 - r2.1 (0x0061)
| | | Serial: E0R1AX5XX
| | | | RX Frontend: 0
| | | | Name: Unknown (0xffff) - 0
| | | | Antennas:
| | | | Sensors:
| | | | Freq range: 0.000 to 0.000 MHz
| | | | Gain Elements: None
| | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz
| | | | Connection Type: IQ
| | | | Uses LO offset: No
| | | | RX Codec: A
| | | | Gain range digital: 0.0 to 6.0 step 0.5 dB
| | | | Gain range fine: 0.0 to 0.5 step 0.1 dB
| | | TX DSP: 0
| | | TX Dboard: A
| | | ID: XCVR2450 - r2.1 (0x0059)
| | | Serial: E0R1AX5XX
| | | | TX Frontend: 0
| | | | Antennas:
| | | | Sensors:
| | | | Gain Elements: None
| | | | Connection Type: IQ
| | | | Uses LO offset: No
| | | | TX Codec: A
| | | | Gain Elements: None
11-15-2018 09:03 PM
Did you solve the problem?
And I encountered this error, i need your help.
[ERROR] [DBMGR] The daughterboard manager encountered a recoverable error in init.
Thanks.
Sincerely,
LeeJell.
12-21-2018 04:49 PM - edited 12-21-2018 04:49 PM
Have you checked the Status field of the returned status of ths function (findsdru) ?
https://fr.mathworks.com/help/supportpkg/usrpradio/ug/findsdru.html
The function returns an array that contains 4 fields as shown in the link, this status will give you more informations about the problem.
I think you should also check the compatibility of your package with your USRP : https://fr.mathworks.com/hardware-support/usrp.html
But maybe MATLAB forum could help you more than us to solve this problem.
12-25-2018 02:37 AM
Thanks, i solved the problem via offical technology supprt.
The reason is that the UHD version is not compatible.
Using an older version of UHD,such as the UHD-3.9.LTS.
05-24-2022 01:59 PM
Hey, can you help me download the UHD3.9 LTS for windows?
