USRP Software Radio
USRP: save fm broadcast in a .wav file
I want to both hear and save my fm data but i am unable to properly save it.I am acquiring the data comntinuously from usrp 2920.Actually the .wav file is created but it does not play.
 My Block Diagram
Message 1 of 18
(1,075 Views)
Hi Gerd Appreciate that you reply and willing to help.
Sir along this issue i am facing another issue in my VI ,that i cant record audio even tat i am able to hear fm radio but the recorded file in .wav format does not play.Attached is a snip of my VI.
I can hear the radio but i am unable to record fm radio.
Kindly suggest what may be the problem
Regards
Message 2 of 18
(954 Views)
Hi umairpak,
According to the error message this is not a problem of your LabVIEW code.
Check your computer…
using LV2016/2019/2020 on Win8.1/10+cRIO
Message 3 of 18
(1,051 Views)
Hi Gerd unfortunately that is not the case!
My pc is fine, something is wrong with my code.I have attached my VI project Kindly check it. When i give a path to the sound record file it creates a path but does not save sound because it of only few kbs.
Have a productive day Thank you
Message 4 of 18
(1,025 Views)
Hi umairpak,
Even though you named that archive "LV2012" the VIs are saved with LV2020, so I cannot open them right now…
The error message shown in your image is not a LabVIEW error message (AFAIK), but a message of your Windows OS…
Message 5 of 18
(1,018 Views)
Sir this is the 2012 program.Kindly have a look.
Note:Change the dequeue timeout to -1(default) and the multi-channel fm will work fine.
Kindly have a look when you have time.Refer to the problem
Regards Umair
Message 6 of 18
(1,011 Views)
Hi umairpak,
Now I could open the VIs.
As I don't have the USRP package installed I reduced your main VI to the bare minimum of playing the waveform sound:
I can run that minimum code without getting an error on my laptop…
Again: the error message you have shown in the image above is not a LabVIEW message. It's a message from your (Windows) OS: so I suspect it's a WindowsOS problem…
Message 7 of 18
(1,008 Views)
Hi Gerd!!!!
1.I said that i cant properly record fm radio .wav files, i did not asked about play. I can successfully play fm radio.
2.My host computer does not have a problem since i can play other .wav files on it.
3.When i try to save my fm radio broadcast it creates the .wav file but does not save any data to it.
Note: please refer to the above posts for problem snips.Gerd as you dont have the usrp soo how come you will solve the problem.
Regards have a productive day.
Message 8 of 18
(992 Views)
Hi umairpak,
From your first message (with an error message claiming "Can't play!"):
1. You wrote you can create wave files, but you can't play them…
3. Attach a VI with the waveform data you want to save in a WAV file: this way we can try to debug your problem. Without your data it's hard to guess! (This also answer the point on trying to help without USRP hardware: the problem seems to be just the saving of a waveform into a WAV file! No need for USRP hardware to tackle that problem…)
Message 9 of 18
(988 Views)
Hi Gerd!
Actually the problem is not in writing .wav file because i can simply call any .wav file in my labview and save it again by just simple read and write commands and it works fine.
But when I try save fm broadcast the problem occurs that it is unable to properly save the .wav file(i mean it just creates a file). When i tried to save fm Broadcast from LabVIEW Modulation toolkit examples "niUSRP EX FM Demod Sound Card (Shift Reg)" it saves the .wav file but for 2s only.I guess i need to change something or add something I am very confused.
Please guide me through this usrp query.
Regards!!!
Message 10 of 18
(981 Views)
