09-19-2017 01:48 AM
Hi all,
I have been facing a problem when I update the firmware of USRP 2950R and 2940R. the error states that "USRP Utilities has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." (The screenshot is attached). This is when the device is connected to the computer through NI-Pcle cable.
I then tried to do the update by using ethernet and NI-MAX. in both cases, the update is done, but the effect of the update does not take place upon the reboot. That is, the device still requires updates after restarting it.
Interestingly enough, I can successfully do updates for other USRP models like NI-USRP 2932. Therefore am not sure if the problem is with the devices or the software in the computer.
Can anyone help me through?
Regards
Abubakar
Solved! Go to Solution.
09-27-2017 03:46 AM - edited 09-27-2017 03:47 AM
Okay, finally I solved it myself, I provided the solution on the thread in the link below:
Regards
Abubakar
