USRP Software Radio
USRP-2974 - Windows 10
I just found this topic on NI website :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DbYASA0&l=fr-FR
Does it means that it is officialy supported ?
Is there any limitation (SFP+ port available) ?
Does anyone have feedback about installing Windows 10 on NI USRP-2974 ?
Thank you.
Guillaume
(3,804 Views)
Hello Guillaume,
The documentation you linked is public and National Instruments accepts that such modification is made.
I found no particular restriction while searching through our database.
Nevertheless, keep in mind that this setup is not usual.
Have a nice day 🙂
Kind regards,
Armand Franquet
(3,772 Views)
Hi Armand,
Thank you for reply.
As you said setup is not usual but it can be very helpfull and autonomous solution for SDR using LabVIEW + FPGA (not communication).
I'll try this installation and i'll report it here.
Guillaume
(3,766 Views)
Hello again Guillaume,
Thanks for your response, don't hesitate to update this topic, helpful for the community 🙂
Good luck for the install 😉
Armando
(3,762 Views)
Could not change the boot priority from the BIOS setup for W10 installation from a flash drive. Any suggestions?
(3,660 Views)
