08-22-2017 07:01 PM
Dear friend,
I am using USRP2943R. Allow me to have some questions.
1. by using configuration utility, I cannot change the IP address by using Ethernet . I mean, I gave new IP address, then, new window pop out very fast says "please power cycle device". But the ip never changes after I reboot the device. Btw, can I change the ip address by using PCI connection, from NI MAX?
2. I want to update the image. The image from PCI connection and Ethernet is the same or not??
3. I played with USRP2932 before, the inbuilt example for USRP2932 still can run by 2943R or not? I ask this is because it seems like NO, the MPSK example says it can not find the device from given ip address. But I have problem about changing IP, so, idk this cause problem or not.
4. Where to find a USRP2943 simple example but device name is from IP address not RIO device name.
Thank you so much for your help!!!!!!
08-28-2017 09:34 AM
I am glad we resolved your issue by setting up the IP configuration properly! Best of luck on your project!
