USRP Software Radio
USRP-2943 sync daughter boards on a single device
I am interested in getting phase aligned input from RX1 of channel 0 and 1 (two daughter boards), but unfortunately they are time but not phase aligned. Can both be aligned to have a zero phase difference on acquisition?
(2,752 Views)
Hi amir13,
If you want to get a zero phase difference between input signals from channel 0 and 1, you need to implement an algorithm to measure the phase difference and calibrate it with a reference signal.
(2,736 Views)
Thanks for your guidance. How do you suggest I can calibrate? Because there is no way external signal can be switched from calibrated signal to normal input without restarting usrp.
(2,721 Views)
