07-24-2018 04:14 AM
This is the USRP 2920 block diagram and explanations in the USRP Help document.
The explanations:
I'm confused about the signals after Mixer is zero-IF or not. If the I/Q components are baseband signals, that is, they are zero-IF signals, why the DDC mixes the signals again?
07-25-2018 09:49 AM
The signals after the mixer are (when combined as I and Q) complex baseband signals, not IF. The DDC in the FPGA serves three main purposes:
Let's say you acquired a 40 MHz signal around 1 GHz, but you want to zoom in on a specific component at 1.05 GHz. You would let the DDC freq shift 50 MHz and decimate to give you just the signal in that sub-band that you want.
The DDC/DUC frequency shift can also be helpful to move your signal away from DC, where the LO feedthrough may be a problem.
