09-21-2017 01:41 AM
I am starting to work on the USRP 2920 with Labview 2017. Is there any particular tutorial or example that I can follow to start working on projects with it. Some good examples that can be implemented would be good to start with. I am a beginner, any help would be great.
Thanks in advance.
Regards
Akhilesh
Solved! Go to Solution.
09-21-2017 03:52 AM - edited 09-21-2017 03:53 AM
USRP drivers installed you should have access to the Examples.
http://zone.ni.com/reference/en-XX/help/373380G-01/usrphelp/installed_examples/
There are also lots of examples and whitepapers on the NI website, which can be found with a quick google search.
