USRP Software Radio
UHD can't find USRP N210
Hi,  I tried to update a N210 with new UHD firmware and fpga First I tried to do both fw and fpa at once and got a timeout error.
After that I tried to do the fw and fpga update seperately.
The fw update succeeded but the fpga update failed with: socket.timeout: timed out his has probably to do with network packets getting lost.
 The big problem is however that the USRP is not responding anymore after it has been powercycled.
 even ping 192.168.10.2 does not give a response anymore.  uhd_find_devices, uhd_usrp_probe or usrp_n2xx_net_burner.py also don't see it anymore.
 Any ideas on how to solve this?   Thanks
(4,172 Views)
Maybe too late but already solved?
Sounds like you bricked it 😕
tried booting the N210 in safe mode? that way is has the default IP adres
otherwise unbrick it : https://lists.gnu.org/archive/html/discuss-gnuradio/2011-04/msg00321.html
or send it back to NI, they'll do it for you
(3,677 Views)
