10-15-2016 05:26 AM
I wonder topic about 1 X 2 MIMO ( One transmitter Two Receiver USRP System ) .I have input bit sequence like '10101010...' on transmitter part. So '1' and '0' bits are lined up in order. 0 comes after 1 , 0 comes after 1 .I want to send this bit sequence from transmitter USRP to channel. On receiver part; how could I set time and set up triggers of receiver USRPs that one USRP will fetch only 1 bits from these squence, another USRP will fetch only 0 bits from thise squence. How Can I synchronize this 1X2 MIMO system like that ? Could you give me advices?
Best Regards.
Solved! Go to Solution.
10-17-2016 06:34 PM
Hi ahmetemir,
What specific hardware and software are you using for this application?
10-18-2016 12:53 AM - edited 10-18-2016 12:58 AM
Transmitter will be 2943R , one of the reciever will be 2921 other of the receiver will be 2943R. Should I use only Optoclok for synchronization? I couldn't write software specific , I couldn't know how I'm able to to implement this system. Software editor is NI Labview 2014. Is there any example program similar to this problem?? Could you give me advices please??
10-19-2016 10:52 AM
Hi ahmetemir,
I think this example will provide a framework for what you are trying to do: https://decibel.ni.com/content/docs/DOC-23677.
10-19-2016 01:32 PM
Thanks for your help, I will review exapmle
02-04-2018 10:32 PM
anyone share with me a VI with Implementing 2x1 MISO system with LabVIEW and NI USRP 2921 using Alamouti code?? I need problem with the estimation channel in the receptor, i used the alamouti code with 2 antennas trnasmitter and one antenna receiver.
