USRP Software Radio
NI-USRP-2974 SFP Ports Communication Issue
I m using USRP-2974 remotely Through Host. Computer. I Have Installed Labview Communication Design Suit 5.0 And USRP Instrument  Driver 20.5 On Host Computer.
RJ45 Ports Communication ok and USRP Detected in Labview Comminication Design SUIT.
SFP Port 0 Communication not Ok   USRP not Detected in Labview Comminication Design SUIT.
SFP Port 1 Communication not Ok   USRP not Detected in Labview Comminication Design SUIT.
Kindly Guide  about Connectivity Issue Through SFP Ports.
(482 Views)
This USRP-2974 host supports multiple, high-speed, low-latency interface options to the FPGA. To setup the device, follow these basic instructions:
  • Configure the host ethernet adapter (enp1s0f0) to use an IP address of 192.168.40.1 and a subnet mask of 255.255.255.0
  • Configure the host ethernet adapter (enp1s0f1) to use an IP address of 192.168.30.1 and a subnet mask of 255.255.255.0 (loopback with SFP+ cable needed)
  • To test communications, ping the USRP FPGA at address "192.168.40.2" or “192.168.30.2”
For more details on network setup, including PCIe connectivity, please see the section Interfaces and Connectivity of the NI USRP-2974 Hardware Resources page.
1G/10G ETH 0 SFP+ port used for 10G ETH connectivity to other ethernet devices. Connects to the embedded Linux computer for communication with LabVIEW RT.
1G/10G ETH 1 SFP+ port used for 1G/10G ETH connectivity to other ethernet devices. Connects to the FPGA. Not currently supported in LabVIEW Communications System Design Suite.
(420 Views)
