USRP Software Radio
NI USRP 2940 configuration with Ethernet
I first programmed FPGA of my NI USRP 2940 device using PXI cable. Now I want to remove the PXI cable and make connection through Ethernet for running that code. Is that possible? If so, please guide me with steps that I should follow.
M Mahboob Ur Rehman
(2,937 Views)
Accepted by topic author Mahboob_ur_Rehman
Hi Mahboob,
The 2940 cannot run custom bitfiles over Ethernet. If you have modified the FPGA, you will need to use the PCI connection to run the code. Ethernet is only available for shipping versions of the bitfile.
Cheers,
Clint T
Clint T.
(2,899 Views)
Hi Clint T,
Thanks for replying. I got your point.
M Mahboob Ur Rehman
(2,892 Views)
