07-03-2012 01:02 PM
Can you please run the niUSRP EX Rx Continuous Async.vi example program and see if the example fails at 5MS/s? You might be able to squeeze a little more performance also if you disable the "Allow debugging" checkbox in the VI Properties under the Execution category
07-04-2012 03:14 AM
The example "niUSRP EX Rx Continuous Async.vi" fails to 5MS / s, it fails even to 3MS / s. However it runs to 2MS / s.
07-06-2012 10:39 AM - edited 07-06-2012 10:40 AM
Hello Yann,
Due to the fact that the example is failing at 5 and 3 MS/s I would suspect the connections to the computer or the ethernet card itself.
Are you running a lot of programs in the background while communicating with the USRP? Are any programs downloading data from the internet?
Does the computer have a network card dedicated for communication with the USRP?
How is the USRP connected to the computer? Through a switch or a direct connection?
Are you using static or dynamic (DHCP) IP addressing?
What is the model of your Dell computer?
07-09-2012 08:36 AM
Hi Anthony,
In order to have a few processes in parallel with Labview, I optimized windows. My attachment showcase processes in parallel with the program during execution. My laptop is not connected to the internet, it is connected to the USRP by a gigabit ethernet connection (direct connection). Also, my PC has a static IP address.
Finally the network card of my laptop is: "Intel(R) 82579LM Gigabit Ethernet Network Connection"
I don't known if my network card is compatible with the USRP. How do I know?
07-09-2012 09:02 AM
Excuse me,
Enclosed my attachment
Yann.G
07-10-2012 07:55 PM
Hello Yann,
Thanks for the information.
Since the USRP is an ethernet device there shouldn't be any compatibility problems with the network adapter in your laptop.
Usually on the bottom right corner of your screen (system tray icons) you can change the power options of the laptop to "high performance" If you don't have a power icon you can go to Control Panel » System and Security » Power Options and select High Performance.
Your antivirus software may also be intercepting network traffic for viruses. I would try disabling the network protection part of the antivirus software and run the example program again.
07-11-2012 07:15 AM
I already changed this parameter, but my problem persist.
I try to have IQ rate = 20MS/s. However, my system goes into overflow. The overflow neaver happens at the same time.
Yet, I've already made several changes, I disable the windows firewall, disabled my antivirus, and also put my power option in high-performance.
Also, size of buffer reception = 2048
I don't understand, why my problem persist.
Yan.G
11-21-2013 07:35 AM
HI,ErikL
I first flash the firmware of the USRP2,
Use the NI USRP Configuraiton Utility found under Start >> All Programs >> National Instruments >> NI-USRP >> NI-USRP Configuraiton Utility
1. Run the utility
2. Insert the memory card into your computer
3. Flash the card
4. Place the Flash card back in the USRP2
5. Plug it in
Everything is ok. and I CAN find the USRP2
BUT, yesterday when I run the program 2x2QAMAlamouti with BER ,I fogot it after I changed the ip address of a usrp2, then I CANNOT FIND the USRP2 by NI-USRP Configuraiton Utility!
I tried to change the PC's ip address about hundreds times to find usrp2,but it did't work!
10-21-2015 07:03 AM
02-01-2016 01:37 AM
3. Flash the card
5. Plug it in
what is the memory card we need to use here..
i didn't get this step2.
Can you expalin me step2 in detail plz...
