You can change the carrier frequency of the transmitted signal on the fly with a property node and the "Configuration->Carrier Frequency property. Also, this post has some good links to other people doing frequency hopping.
If you are asking new questions we generally ask customers to begin new forum posts.
To address your questions:
1. LabVIEW Modulation Toolkit comes with example programs for FSK and PSK modulation schemes which you could combine with the methods above to change the carrier frequency of the signals.
2. Regarding synchronization this is a pretty broad topic. I have included some links below that I think you may find helpful.
