USRP Software Radio
FM-Transmit voice data through USRP-2901
mathias19100,
For wireless transmission, yes, you will need an antenna.
You can also use the device for wired transmission, over a coaxial cable.
Patrick O.
Applications Engineering
Message 11 of 13
(1,653 Views)
hello,
thanks you for information but i have other question.
now, i want use my USRP card (USRP 2900) with Labwindows CVI, that is possible ? there is already library or driver for usrp on CVI? i have not found anything yet.
thanks you
MP
Message 12 of 13
(1,480 Views)
Hi MP,
If you are looking to use the USRP 2900 with text-based programming languages, you can use the Ettus UHD driver (USRP Hardware Driver), which supports C/C++ and should be usable with CVI. The NI-USRP driver is only supported in LabVIEW, LabVIEW NXG, and LabVIEW Communications software environments, as is noted in the NI-USRP 18.5 Readme.
What drives the interest in using the LabWindows/CVI environment for your application?
Cheers,
Paige
Message 13 of 13
(1,471 Views)
