08-07-2012 10:52 AM
hi to all.
Does enyone know where i can find or get drivers for NI USPR 2920? Drivers wasn't come with the device...
thanks
08-07-2012 11:06 AM
Hello Pixus,
All National Instruments drivers can be found at http://www.ni.com/downloads/drivers/ including drivers for the USRP if you search for NI-USRP. At the current moment, the most recent version is 1.1
08-07-2012 11:20 AM
Hello Anthony,
thank you for fast reply.
I already have those drivers, but with them I can't connect my USRP device with PC, so I thought there is some driver that
I don't have. Like some installation drivers or sometime like that. Does exist something like that?
Pixus
08-07-2012 11:46 AM
Hi Anthony,
do you know how to connect USRP device with PC, if I done everything that was written in User manuals?
Is there any possibility to change IP address of USPR device, if USRP utilities does not see the device?
Pixus
08-07-2012 11:52 AM
Hello, for the USRP 2920 and 2921 the only driver needed will be the NI-USRP driver.
From your other posts, here is what I gathered:
The green light on the ethernet port is a good indicator, it means that the ethernet port is enabled and gigabit is supported by your network interface
Light D means the firmware was loaded.
Light F means the unit is powered on.
Light E should also be on to indicate a reference signal for the local oscillator
08-07-2012 12:10 PM
everything you wrote is correct.
Static IP that I was set is 192.168.10.1, and subnet mask is 255.255.255.0.
the default IP of the USRP device should be 192.168.10.2.
Maybe the IP address of the device was changed in the past, so maybe the subnet masks isn't the same.
Is there any way to reset IP address of the device to default IP address?
Pixus
08-07-2012 12:41 PM
You can reset the IP address by following this post here: How can I reset the USRP IP address to the default 192.168.10.2?
08-07-2012 01:15 PM
Antony,
if I open enclosure of the device, and push the safe mode button to reset IP address, how can I go back in operational mode
when I change IP address to default value?
What if I do something wrong and damage the device?
08-07-2012 01:18 PM
Anthony,
there is 2 push up buttons, and both are the same. Wich ona should i push? Do you have any electrical scheme of ihe device?
thanks,
Pixus
08-07-2012 02:20 PM
Hello -
I have 2 recommendations:
1. If someone else used the USRP or attempted to change the IP address they could have placed it on a different subnet.
(default of the USRP is 192.168.10.2)
2. The ethernet controller is not actually a gigibit controller
I recommend the first thing you try is installing the NI-USRP driver on another computer with gigibit support (LabVIEW is not needed for the utility). This will quickly eliminate or confirm several possiblities.
