Does NI have any embedded USRP like ettus? My supervisors are planning to employ some stand-alone USRP's in an area. The USRP's will be used to measure channel impulse responses. However, they should be stand-alone, i.e., no laptop/desktop will be connected to those. Does NI provide any such USRP? Or, is USRP E110 my only choice?
Currently, NI only offers 2 versions of the USRP--both Ethernet based. If you want an embedded version, you will need to purchase if from Ettus Research. The USRP E100/E110 will be the only options, and they will not work with the NI-USRP driver.
