USRP Software Radio
Agilent CXA signal analyzer N9000A Frequency range, 9 kHz to 7.5 GHz
Hello, I am currently trying to get the CXA signal analyzer N9000A to communicate with our PC using the TILE software. I tried some drivers on the site, but I am not sure if I am using the correct driver. The GPIB is still not recognizable in the device manager.  Please help.
(1,030 Views)
Accepted by topic author SP1026
Based on the GPIB adapter, you need to install the driver, if you're using NI GPIB adapter, install NI-VISA drivers from https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(1,027 Views)
Thanks for the reply. I tried downloading the link you mentioned, but it still states Windows does not have a driver associated with your device when using "NI MAX"
National Instruments (GPIB_USB_HS)
M/N GPIB-USB-HS
P/N 187965H-01L
(972 Views)
