03-05-2019 07:11 AM
Dear all:
When I using usrp-2932 with srsLTE's end and epc, there is a error emerge all the time.
showing as follows:
This error message is from uhd, what should I do to solve it?
And the epc and enb information are as follows:
and usrp probe:
I'll very appreciate it, if you tell me the solution after reading!
If you need more information , please tell me.
Thanks!
03-08-2019 02:59 AM
I notice that you are using Linux. Were you able to detect the USRP 2932 properly?
From this article, it is stated that USRP drivers do not have support for Linux.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFlxSAE&l
03-08-2019 03:15 AM
03-12-2019 10:40 PM
Not sure wheter srsLTE supports USRP-2932. It is not in the list of tested hardware.
03-21-2019 11:56 PM
Hi guozi,
As your screenshot, USRP-2932 uses N210 motherboard.
According to the GitHub(https://github.com/srsLTE/srsLTE), N210 is not included in tested USRP systems.
The hardware limitation is that the master clock of the N210 is fixed at 100 MHz, which is not a multiple of common LTE sample rates.
10-13-2021 03:55 PM
Hi guozi, I am having the same issue with N series device as well. Can you point it out to me the steps that you followed when running srsenb command.
