USRP Software Radio
A uhd error of usrp-2932
Dear all:
When I using usrp-2932 with srsLTE's end and epc, there is a error emerge all the time.
showing as follows:
This error message is from uhd, what should I do to solve it?
And the epc and enb information are as follows:
and usrp probe:
I'll very appreciate it, if you tell me the solution after reading!
If you need more information , please tell me.
Thanks!
(3,831 Views)
I notice that you are using Linux. Were you able to detect the USRP 2932 properly?
From this article, it is stated that USRP drivers do not have support for Linux.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFlxSAE&l
(3,797 Views)
Hi, Thanks for your attention! I have burned the uhd that compatible to Linux. And when I used gnu-radio, all things were right with nothing error. But got wrong when using srsLTE.
(3,795 Views)
Not sure wheter srsLTE supports USRP-2932. It is not in the list of tested hardware.
https://github.com/srsLTE/srsLTE
(3,774 Views)
Hi guozi,
As your screenshot, USRP-2932 uses N210 motherboard.
According to the GitHub(https://github.com/srsLTE/srsLTE), N210 is not included in tested USRP systems.
The hardware limitation is that the master clock of the N210 is fixed at 100 MHz, which is not a multiple of common LTE sample rates.
(3,716 Views)
Hi guozi, I am having the same issue with N series device as well. Can you point it out to me the steps that you followed when running srsenb command.
(2,405 Views)
