UKTAG – UK Test Automation Group
Pluggin' into Switch Executive
Does anybody have some hints on how to plug in to SwitchExecutive to integrate an own (non-NI based) switching device? In my  case, I am thinking about integrating a pneumatic switching matrix with 72 valves...
If it is possble at all....
Cheers
Oli
(5,936 Views)
Accepted by topic author Oli_Wachno
I never tried that but I've read that with IVI Switch driver you should be able to accomplish this (or at least that what I understand). So, you need custom IVI Switch Driver.
Check this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x12BCAQ&l=pl-PL
And this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1s7CAA&l=pl-PL
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(5,929 Views)
Adding to Michal's links, I have managed to use it with pickering devices. You need to make it IVI compaitble.
Link: https://www.pickeringtest.com/kb/software-topics/using-pickering-switches-in-various-programming-lan...
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(5,924 Views)
@Michal
@Sree
thanks for the information, it'a a good starting point! The only thing, which bothers me a bit is that I was not yet able to find a .net template for a IVI switch driver. CVI is not part of our regular toolchain, so I am a bit reluctant.
I shall keep on searching. As of now, we're evaluating the feasibilty of this concept in general.
Cheers
Oli
(5,886 Views)
Hello Oli,
See also:
Using IVI Drivers with LabView
https://www.ivifoundation.org/downloads/IVI%20short%20guides%202015/Using%20IVI%20with%20LabVIEW.pdf
Writing IVI driver with LabWindows/CVI
https://www.testandmeasurement.com/doc/writing-an-ivi-driver-0001
Seems that LabWindows is first choice...
BR
Eugen Wiebe
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(5,884 Views)
I'm not the expert but look for ".NET IviSwtch"
https://www.ivifoundation.org/downloads/Class%20Specifications/IVI-4.6_Swtch_2011-08-25.pdf
There is .NET IVI as well.
Michał Bieńkowski
CLA, CTA, CPI
(5,882 Views)
