UI Interest Group Documents
Vertical Bar Chart
A few years ago I had a need to represent the relative power of 18 different channels. This suggested a vertical bar chart. This is a stock multiplot waveform graph. Then to color each one individually inspired this solution. The data is put into a diagonal matrix. Each row is a plot and can be given a color, but because there is but one value in the row only one bar in the chart is affected. All other entries in the row are NAN. In this example I colored each according to the highest threshold it was under. Running the vi (which was done in version 7.x and will open nicely in 8.6) will put random values in each position.
Comments
Rick_K
NI Employee (retired)
on
This is really well done. I am using a bar graph from the community on an internal application but this one is way better. I should point out that LabVIEW 2009 also has a bunch of new math plots including a nice 3d bar chart. However, for 2D this is one of the better ones I have seen especially with the programmable thresholds. Thanks for sharing Paul.
brijesh
Member
Member
on
Nice way to Plot Bar Graph..
Thanks for sharing...
CLAD
Labiew programmer
Ahde
Member
Member
on
非常漂亮的柱状图!
Contributors
