UI Interest Group Documents
'Industrial' Numeric Control
This images for this custom control were created using simple shapes and shading in Microsoft Powerpoint.  The source .pptx file is attached if anyone wants to create other indicators based on a similar theme.
Comments
Active Participant Thoric Active Participant
Active Participant
This is astounding! Thank you very much for sharing this concept with us! I will most certainly be attempting to create some of my own custom controls this way - it's so easy yet the result looks so professional!
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Active Participant Elijah_K
Active Participant
If you can, share what you come up with.  I'm eager to see the controls the community is making!
Elijah Kerry
Chief Product Manager, Software Platform
_______________________________________________
Follow my Software Engineering for LabVIEW Blog
Member JetYo
Member
thanks for the stuff you‘v shared,好人一生平安
Member GATTO
Member
PUEDO CAMBIAR EL TIPO DE FUENTE DEL NUMERO??
Active Participant manumohannair
Active Participant
Any one could supply me 8.5 version of this control ?
Member G'Ramy
Member
after a long  i'm seeing a
simple and good numeric control....
Member Sumithra_Nagappan
Member
may i know how create such control
Knight of NI Knight of NI
Knight of NI
showing the radix is a bit ugly. That should be corrected. Rest looks great.
LabVIEW Champion Do more with less code and in less time
Active Participant A.Salcedo
Active Participant
can all your controls be for commercial use?
Contributors
