To save space at the user interface, I created an XControl that you can collapse to the title only or expand to see all.
Each Control/ Indicator can be collapsed or expanded and all of them can be stucked together.
Each Control is referenced to set the dependance to the others. Within the properties you can set to which control each is stucked, if the control initially is collapsed or expanded and the color of the control. The Name is set to the control's label.
The example GUI it looks like this:
In the block diagram you have to pass the control references so that the following controls can snap to the above ones:
The XControl is written in LabVIEW 2014 and additionally convertet to LabVIEW 2011. Please free to download and test it.
This is Version 2 with color settings.
can you please post a 2011 version?
sure, done
awesome work mate
Looks great! Good job and thanks for sharing.
Great job! Thanks for sharing.
Can you explain how Resize.vi works? What is the purpose of the Loge? Does it resize in 20 small steps?
Can more controls be added easily and can the colour scheme be changed? It would be good if the UI conformed with Win 8 style guide.
Yes, resize and replace work in little steps to look like an animation. When an object resizes all objects in the chain are replaced whitin the same steps.
A color scheme is a good hint to do but Win 8 conformance is not a target for me. There are other examples here which bring you Win 8 controls.
can u please post a 2010 version also??
Great UI nad great concept!
Is it possible to put a cluster inside the XControl instead of a numeric?
Danielle
@gargrahul Sorry, I can't convert it to any version.
@dsavir Until now it's only an example with numeric controls. I have an plugin-like concept in my mind to use it with any control or cluster, but I don't have time to realize it.
