08-16-2016 01:34 PM
I've added a Waveform Chart in version 1.3
08-17-2016 02:46 AM
I like it, well done!!!
When I click with the mouse into a numeric control, the numeric field overlaps the increment/decrement button.
Does anyone have the same effect?
08-17-2016 04:11 AM
Yes, but there doesn't seem to be a way around this. The incr/decr buttons on the original LabVIEW controls are designed to sit outside the numeric box, but I preferred it inside the box. One could shorten the actual text-entry field, but then there would be an annoying blank area when the incr/decr buttons are hidden (as on an indicator). I decided to just accept the overlap when entering a value.
There are several such tradeoffs made in this package (LabVIEW controls have a lot of quirks). I did a lot of experimenting to try and come up with a good set of compromises.
08-17-2016 04:38 AM
Hello James
Thanks for your response.
Ok, this is a conscious decision. I can live with that.
I will continue to use your controls with a lot of joy.
Kudos to you!
10-20-2016 08:06 AM
Hi! Great Work! But it would be more useful if there is Waveform Graph available...
10-20-2016 08:32 AM
10-20-2016 09:19 AM
The hover buttons are based on system controls, which don't support different colours for ON/OFF states, so I had to make the choice of just using flat PNGs for the ON state. I use these as "action" buttons, which do something and do not stay in an "ON" position, so they work well for me
What you need is something based on regular LabVIEW controls. I can't seem to attach a VI here, but I'll post it on LAVA here.
11-17-2016 06:09 AM
Thanks! just what I need. Once tried the Silver controls but their minimum size is just too big.
12-06-2018 04:19 PM
Really enjoying these controls, but have hit a stumbling block with the xy graph. I'm trying to create additional Y scales, and swap sides but that option seems to be disabled. Its working for waveform charts and regular charts, but not the xy graph. In fact just duplicating a scale does not behave as expected, the second scale falls on top of the first.
Is there an easy fix for the swap sides that would allow the usual xy graph behaviour?
I tried property nodes and can move the scale manually. That's fine for 2 Yscales on the left, but if you want a Yscale on the right ticks and label stay on the left. I can move the Yscale label with property nodes, but unlike normal behaviour the text read S-N not N-S like a typical swapped scale label. I don't see a way to move the tick labels to the right, or reverse the label direction.
BTW I'm using v1.7.1.26 installed through VIPM. I see there's a v 1.8, but the download link from lavag.org is broken (https://lavag.org/files/file/287-flatline-controls/) and it doesn't show up in VIPM. If its fixed in there is there another download link?
Thanks.
Craig
12-06-2018 04:56 PM
I think I have "Advanced>>Auto adjust scales" turned off on that (for why see this LAVA link). Turn it on and it should work normally when you add a second scale.
