Troubleshooting Hardware
Roborio2.0 Ethernet Port Pins
So at our last comp (Ft worth), a CSA told the team that one of the pins on our Ethernet port on our roborio 2.0 was bent and that was causing our in-match disconnects. This was after a little back and forth and yes, we switched out the rio during the comp and the issue did go away.
How can we get this repaired or replaced?
(1,206 Views)
Hello FMHS Tech Club,
This is Oscar from NI. I have sent you a direct message for next steps.
Thanks!
(1,184 Views)
