Troubleshooting Hardware
Roborio 2.0 not turning on
Hello, our roobrio has died, we have only been using the bot for a few days and we taped up all our ports, we were driving it slowly and it randomly just died, we checked voltage on the power connector and it says 12v, what can we do now?
(100 Views)
My name is Esteban Sanarrucia from NI,
Could you please verify that there is no debris in the roboRIO that could be causing a short? You can use compressed air and a brush to remove any debris inside. Additionally, shaking it vigorously might help.
Can you double-check the polarity? Ensure the positive is connected to the "v" and the ground to the "c".
(73 Views)
hi, thank you for the tip, we will try that today and update you.
(68 Views)
unfortunately that did not work, roborio is still dead
(59 Views)
