Troubleshooting Hardware
RSL on rio-2 0 volts, IE no RSL everything else works fine
Robo rio 2, everything works on it except the RSL. we've swapped lights and measured the voltage at the pins. 0.
P/N: 133340B-01L
S/N : 3415ABA
Thanks!!
This is our spare for competition . we have a week 1 event. anychance we can get 1 ASAP?
Thanks!
Chris (team 4230)
(200 Views)
Hi Mortobot,
Thanks for posting on the forms. I'm Matthew with NI.
RSL is controlled in software, and "off" is the normal state.
Can you please deploy a blank (no team code) project and see if the light starts blinking while or being on while connected and disabled V enabled?
(194 Views)
We absolutely can do that, however, we tested it via enabling and disabling a code project, and genearlly the light is on when code is up and running. but we will do this test and get back to you!
(182 Views)
ok we did that . we deployed the same program to this rio and another one. the other one the light blinked, this rio, the light did not blink.
(161 Views)
I've sent you a private message on next steps
(140 Views)
