The Daily CLAD - Page 2
Community Browser
20 Comments
16 Comments
12 Comments
Consider the VI, which Numeric Array In resulted in a Max Value of 5.56 and Fractional Index of 0.177829?
Read more...
17 Comments
9 Comments
You are tasked to write a VI?
INPUT(s): 1D Array (Numeric Array In) of I32 numerical values.
OUTPUT(s): 1D Array (Numeric Array Out) of I32 numerical values.
FUNCTION:  The VI must return in Numeric Array Out the contents of Numeric Array In with all duplicate values removed.
Read more...
16 Comments
15 Comments
18 Comments
12 Comments
19 Comments
INPUT(s): 2D Array (2D Samples Array) of DBL precision numerical values.
OUTPUT(s): 2D Array (Numeric Array Out) of DBL precision numerical values.
FUNCTION:  The VI must calculate the average value for each column in 2D Samples Array and append that average value to the bottom of the column.
Read more...
18 Comments
13 Comments
13 Comments
14 Comments
Assuming Numeric Value In is set to 1.  Which of the following VIs results in Numeric Value Out = 1?
Read more...
15 Comments
12 Comments
15 Comments
If Channel is set to 1, what are the contents of Numeric Array Out following execution of the VI?
Read more...
8 Comments
Which of the following satisfies the equation?
Read more...
14 Comments
7 Comments
15 Comments
If the VI below is created, saved and then executed twice, what are the contents of Numeric Array Out following the second execution?
Read more...
13 Comments
13 Comments
Which of the following shows possible contents of DAQmxData.csv following execution of the VI?
Read more...
23 Comments
13 Comments
17 Comments
17 Comments
What are the contents of Key Names Array Out following execution of the VI?
Read more...
