Which of the following options most closely describes VI Server?
a) VI Server is a set of functions that allows you to dynamically control front panel objects, VIs, and the LabVIEW environment.
b) VI Server is the version of the LabVIEW designed for remote deployment.
c) VI Server helps you programmatically generate, edit, and inspect LabVIEW code.
d) VI Server is a suite of tools for Microsoft Visual Studio designed to help engineers create test and measurement applications in .NET.
