The Daily CLAD
Community Browser
The Value and Val(sgnl) Properties
SercoSteveB
What is the difference between the following property nodes.
a)      The Value property sets the value of Boolean to FALSE, whereas the Val(Sgnl) property sets the value of Boolean to FALSE and generates a Value Changed Event.
b)      The Value property sets the value of Boolean to FALSE, whereas the Val(Sgnl) property sets the value of Boolean to FALSE only on the first call to the property node.
c)       The Value property sets the value of Boolean to FALSE, whereas the Val(Sgnl) property sets the value of Boolean to FALSE and sets the Front Panel Control blinking.
d)      The property nodes are functionally the same; the naming convention has been modified from the right-click shortcut menu.
Comments
