Consider the two SubVIs called in the screen capture below. Both use the 4x2x2x4 connector pane have a single connected terminal. These are identified as Terminal 'A' for SubVI #1 and Terminal 'B' for SubVI #2.
Which of the following is\are TRUE regarding the Terminals.
a) A and B are connected to different areas of the Connector Pane
b) A is linked to a Control within SubVI #1 and B is linked to an Indicator within SubVI #2
c) LabVIEW Cleanup Wire has modified the direction Terminal A exits the call to SubVI #1
d) Steve has adjusted the screen capture through the power of GIMP
