There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
No, you should not get an error. The timeout does NOT cause an error. If you did get an error, my guess is error code 1 because you did not use shift registers on the FOR loop.
Assuming complete isolation, I would still expect the value to be 0 since that is the next value in the queue. So the only thing I can think of is you were messing around with another VI that also named the queue StevesQueue and it enqueued 100 elements and dequeued 99 element. This is one of the reasons I do not name my queues.
Perhaps if you shared some code we could help debugging.
