The Daily CLAD
Community Browser
Re: LabVIEW Symbols 'The Little Black Square'
SercoSteveB
Through the Tools menu it is possible to configure LabVIEW to display the symbol identified by the arrow (the little black square).  What does 'the little black square' indicate?
a) LabVIEW is allocating memory space in the form of a buffer
b) LabVIEW is performing a concatenation on the Initialize Array node Output
c) LabVIEW is showing an output coersion dot
d) LabVIEW is indicating that the output array size is 10 or more elements
Comments
Not applicable
Answer is A
nmpundlik
Ans: A
dyamanna
Ans : A
crossrulz
Knight of NI
A
GCentral
Musale
explaination please..
nmpundlik
Hi Musale..........
        See this explaination.
Select Tools»Profile»Show Buffer Allocations to display this window.
Use this window to identify specific areas on the block diagram where LabVIEW allocates memory space in the form of a buffer.
Place a checkmark to arrays you want to see buffers for and click the Refresh button. The black squares that appear on the block diagram indicate where LabVIEW creates buffers to allocate space for data.
So answer is:
Musale
got it.Thanks for the explaination nmpundlik..
Kumarhatti
ANS : A
Asha_Nagaraj
Ans is A
RAMESHB
Answer is A
mini09
Nice things to note . great explanation nmpundik...
VSC
Pundlik, good stepwise explanation. I agree with the answer A.
SercoSteveB
Answer: A. Nice one DavidCorney, nmpundlik, dyamanna, crossrulz, Kumarhatti, Asha_Nagaraj, RAMESHB & VSC
The longest list of correct answerers so far.
What are we characterising this question as;  Compiler Optimisation?
adiveppa
Ans is A
ashwinilele
A
